Ok what the Hell?
@Docgrievous Cable or OBD port ? Cables might only have the pins they need but they are mostly, sounds like yours is protocol specific 5 or 6 pins would do that. Get a ELM 327 bluetooth adaptor and Torque for android or Iphone and you will good for monitoring. It can not do ABS codes or LR specific things
There is only one OBDII diagnostic socket. You say "I can even do the Bluetooth thing, sooooo ..."
"Sooooo" is the right question. So what? If it's working, what's your problem? What the hell?
Have you checked the Electrical Circuits PDF or the Electrical Library PDF to see how many wires should be going to the diagnostic socket? Not how many pins and recesses there are, but how many wires should be there?
