Okay idea for a winter tire and rim?
So I need a quick fast cheap fix for the winter snow. My current tires are a death trap on the smallest amount of snow.
What are your thoughts on these BMW rims with Michelin's Pilot Alpin PA2 Performance Winter Tires. The tire is a little smaller 245/50/R18.
I could get the set for 300$
Provided they are the same PCD fixings and the centre boss is the same diameter as a D2 and also the offset is approximately the same or similar to a D2 you appear to be onto a winner. The 50 profile seems a little shallow for snow/winter tires but if the tire pressures are inflated correctly there should be no worries.
Roverrocks
01-02-2014 12:45 AM
collin Barrows
Audio/Visual Electronics
08-22-2011 11:22 PM
vishrb
11-19-2010 01:09 PM
