Okay idea for a winter tire and rim?
Old Dec 10, 2016 | 05:22 PM
Ursula's Avatar
Default Okay idea for a winter tire and rim?
So I need a quick fast cheap fix for the winter snow. My current tires are a death trap on the smallest amount of snow.
What are your thoughts on these BMW rims with Michelin's Pilot Alpin PA2 Performance Winter Tires. The tire is a little smaller 245/50/R18.
I could get the set for 300$
Old Dec 10, 2016 | 05:29 PM
Dave03S's Avatar
The load rating is not sufficient.
Old Dec 10, 2016 | 05:34 PM
OffroadFrance's Avatar
Provided they are the same PCD fixings and the centre boss is the same diameter as a D2 and also the offset is approximately the same or similar to a D2 you appear to be onto a winner. The 50 profile seems a little shallow for snow/winter tires but if the tire pressures are inflated correctly there should be no worries.
Old Dec 10, 2016 | 05:35 PM
Well spotted, good point.
Old Dec 10, 2016 | 05:43 PM
The correct load rating should be 105 to 112 depending on the tire section and construction. Also checkout the speed rating. It should be a minimum of H or above.
My tires are way above the minimum required and are 107Y for load and speed respectively.
Roverrocks
Jan 1, 2014 11:45 PM
mln01
Dec 19, 2012 09:46 AM
collin Barrows
Audio/Visual Electronics
Aug 22, 2011 10:22 PM
vishrb
Nov 19, 2010 12:09 PM
tornado_735
Sep 25, 2010 08:42 PM
