Old Man Emu springs ?
I got a set of springs from a friend of mine that should be OME mediums. He isn't sure if he gave me the right ones because they were mixed in with some stock springs in his garage. Is there a way to identify these springs(markings, paint, etc.). These seem to be color coded. They are black springs but have different color stripes of paint going down the side of them (green, white, etc.).
Those are stock springs. They are marked at the factory with those colors to indicate spring rate and such. OME springs will just be black. Pay attention when you install the springs because OME springs are different front and rear as well as left and right. When you get OME brand new they come marked with tags for A and B referring to A for driver side and B for passenger. I didn't look close enough when I installed mine to tell if they were marked directly on the spring.
Ok, he must have givin me the wrong ones. I found this site that has the color coding for stock springs and these are color coded. Looks like the OME's have a tag on them with the Part #
http://www.landroverorphanage.com/sh...e/5?shop_param=
honda50r
08-20-2012 04:42 PM
mikemeyer0
03-30-2005 06:17 PM
