OME kit installed
Old Dec 5, 2009 | 04:19 PM
jeffo's Avatar
Default OME kit installed
Well, the 10 year old SLS bags front springs and shocks have been replaced with an OME 2 inch kit from Lucky 8 Rovers. They were very helpful and shipped it to Texas in 4 days because the drivers bag was blown. I am very happey with the medium rate springs and the 3 hour install time. Next is new tires, what size is the next step up from the 255/65/16. The old suspension was so worn that I have gained 4 inches of ride height. Thanks for the information on this forum.
Jeff
Old Dec 5, 2009 | 05:38 PM
oysterhead's Avatar
i'd go 265/75....other options (in order):
265-75-16 10.43" wide x 31.6" Tall
265-70-16 10.43" wide x 30.6" Tall
245-75-16 9.64" wide x 30.5" Tall
235-85-16 9.25" wide x 31.7" Tall
Old Dec 5, 2009 | 05:49 PM
jeffo's Avatar
Thanks for the information.
Old Dec 5, 2009 | 06:10 PM
Have you totally shut down the SLS thru the ECU, if not you will have battery issues.
Old Dec 5, 2009 | 06:19 PM
jeffo's Avatar
Mike,
I have not found a local shop with the correct scanner. What issues can this cause? I do have the air pump and the ride height sensors unhooked. Thanks for your help.
Jeff
Old Dec 5, 2009 | 06:24 PM
Well, in the mean time, pull your relay and fuse for the SLS, in the engine compartment. You will still have a warning light on but less chance of draining your battery.
Old Dec 5, 2009 | 06:42 PM
jeffo's Avatar
Compressor disconnected, the only fuse I found for SLS is also for ABS so I left it in. I am waiting for a reply from a shop in Austin that works on jags and rover to see if they can retrain the ECU for me. When I disconnected the ride height sensors the chiming stopped so thats good.Thanks again Mike
Jeff
Old Dec 5, 2009 | 11:02 PM
oysterhead's Avatar
jeffo, sorry I didnt check to see if you have a D1 or D2.
if you have a D1, you will have to do some trimming of the rear wheel well to fit the 265/75. if you don't want to trim, the 265/70 (hard to find) and 245/75 are the way to go.
Old Dec 6, 2009 | 06:43 AM
Torancis_LR's Avatar
Jeff, put up some pictures of your newly lifted truck! We appreciate before and after shots of them
Old Dec 6, 2009 | 07:00 AM
jycsalas's Avatar
Pictures?????
