OME lift ordered
Old Apr 2, 2011 | 05:48 PM
RAYMAN975's Avatar
Default OME lift ordered
OME HD 779/762 springs, check, OME Nitro Sport shocks, check, OME steering stabilizer, check, 4 brake rotors, check, Akebono brake pads, check, rear right caliper, check, bloody knuckles and cursing, check hahaha :P oh, and a happy Land Rover, check
lift ships on the 15th, i will post pictures and measurements of before and after. brake parts will be here monday morning. my rear right caliper was hanging up, tore up the pads on that corner, only about 1/16" of pad left on that corner(took caliper apart, pushed in piston to see if i could keep it from hanging up but it still drags), rotors were grooved badly all around though, but plenty of pad left, ithink they are all original, 92k miles, everything needed replaced soon anyways
any tips or reminders? i will be spraying all bolts with PB Blaster days before, and will reassemble everything with anti-sieze. i have the RAVE downloaded for the torque specs
Old Apr 22, 2011 | 01:46 PM
RAYMAN975's Avatar
pick up my lift today might put it on tonight, if not tonight, i will start it early in the morning. heres before
Old Apr 22, 2011 | 02:33 PM
thospb's Avatar
If you have not started yet, can you take measurements from the ground to the trim ver the wheel on each corner? I am curious about how high the actual lift is. Also, who did you order from, recommendations? I am ready to order the same.
Old Apr 22, 2011 | 06:14 PM
sloppyjoe's Avatar
even at tinker pace it should be no more then 4 hours.
i did mine in my tiny garage in the cold in under 3.5hrs stopping for a couple beers in between fronts and rears.
Old Apr 23, 2011 | 08:44 AM
RAYMAN975's Avatar
no i was expecting it yesterday, but it didnt come. hopefully today, if not, then definitely monday. being easter weekend and all. i cant wait! and ill take measurements today. ill take the measurement from the center of the wheel to the bottom of the flare, more accurate, tire "bulge" will vary etc.
Old Apr 28, 2011 | 02:35 PM
RAYMAN975's Avatar
After
Old Apr 28, 2011 | 02:39 PM
thospb's Avatar
Your truck looks very nice. I just ordered the same from Lucky8 this AM, hope to see it next week.
Old Apr 28, 2011 | 03:47 PM
Bundu's Avatar
Banned
Like!
Old Apr 28, 2011 | 10:33 PM
sloppyjoe's Avatar
needs tires
Old Apr 29, 2011 | 07:28 AM
sloan74's Avatar
Love it. Now your cooking with grease...
You going 33 or staying with the 31" tire?
