OME Spring rates.
Old Mar 6, 2010 | 11:43 PM
Jason_B's Avatar
Default OME Spring rates.
I am debating on getting the 762 or 781 springs in the rear for lifting my Disco II. I have a winch bumper and eventually a winch up front so i think i should go with 779 in the front, but i wont have too much weight in the back. Other than camping gear for two people and a small tool chest, there is never too much weight in the back. On the chart i am looking at it says
781-Medium/Heavy Duty (unspecified)
762-Heavy Duty (220 lbs.)
763-Extra Heavy Duty (440 lbs.)
I don't think i want the 763 but anyone with any experience with any of these springs on a disco II, i would appreciate the help!
Old Mar 7, 2010 | 10:38 AM
Jason_B's Avatar
Anyone have any ideas here?
Old Mar 7, 2010 | 11:29 AM
I think I would just go with the HD's all the way around.
That way your truck will sit level.
Old Mar 8, 2010 | 03:09 AM
Urban Panzer's Avatar
Got OME 779's on mine, already have a winch, and the ARB is VERY soon!!!
Old Mar 8, 2010 | 09:32 AM
Use a 751 H.D. from a D1 for the front and a 762 in the rear with a set of D1 lower spring mounts and you will have a great set up.
The 779 won't hold up in the front and the 781 are just not enough to balance out the front to rear vehicle movement.
More questions, send me your tele number and I'll call you.
Who's shocks are you planning on using? Check out the prices at Lucky 8, best around and make sure to get a new stabilizer.
Old Mar 8, 2010 | 10:37 AM
Jason_B's Avatar
I have a d2, il pm you my number, so far I am leaning on the 779 front and 762 rear, I was planning on the ome 107 108 shocks
Old Mar 8, 2010 | 11:19 AM
Interesting you say that about the 779's. seem to be well respected from what I have read everywhere else, each to their own tho.
Old Mar 8, 2010 | 11:30 AM
I am basing it on wheeling 2 to 3 times a month, running a winch and bumper and doing trails like the Sierra's, Death Valley and Colorado where the truck is put thru some pretty extreme work outs.
My 779 dropped over an inch and a half within 3 months, replaced with 751's that now have apx 95,000 miles on them with no drop.
Pretty much depends on the type of wheeling.
Old Mar 8, 2010 | 12:33 PM
I take on board what you say Mike, listening to others "experiences" is what helps eveyone do the little bits and bobs,
"if" my OME's droop that much in 3 mths, then they'll go back for new ones!!, that simply should not happen.
Old Mar 8, 2010 | 08:57 PM
Jason_B's Avatar
Thanks for the help today mike! I have seen the installation video with the rover dog, and i am confidant in the process, but if i were to use the lower spring mounts, how would put them on? Thanks again for the help and the pictures!
