one tail light much brighter than the other
As the title suggests the passenger side tailight runs like a brake light. Wife just pointed this out. Is this a wiring issue or a bulb issue or something else? I haven't looked into it yet but any suggestions would be appreciated. Thanks.
Do you have your foglights on? If so try turning off the foglights and looking at the taillights again. (many European cars have a rear safety light which is the brake light on one side, that comes on when the foglights are turned on so people following can see you in the fog).
The rear fog lights shut off when you turn the lights off and you must turn them back on to get them to work again, so its not that.
Probably the wrong watt bulb in there.
Swap left and right side bulbs and see if the bright light follows.
there are 2 brake light bulbs, 5wt 12 vt if i remember i just changed mine a few weeks ago. when you take the taillight lens out there are 6 screws to take the back off and there are 4-5 bulbs.
Externet
Aug 26, 2013 06:45 PM
