one tail light much brighter than the other
Old Feb 19, 2013 | 04:37 PM
mtrdrms's Avatar
Default one tail light much brighter than the other
As the title suggests the passenger side tailight runs like a brake light. Wife just pointed this out. Is this a wiring issue or a bulb issue or something else? I haven't looked into it yet but any suggestions would be appreciated. Thanks.
Old Feb 19, 2013 | 06:50 PM
Bkreutz's Avatar
Do you have your foglights on? If so try turning off the foglights and looking at the taillights again. (many European cars have a rear safety light which is the brake light on one side, that comes on when the foglights are turned on so people following can see you in the fog).
Old Feb 19, 2013 | 06:57 PM
mtrdrms's Avatar
I don't use the fog lights but ill check. The rear fogs are in the bumper. I'm talking about the rear tailights.
Old Feb 19, 2013 | 08:15 PM
The rear fog lights shut off when you turn the lights off and you must turn them back on to get them to work again, so its not that.
Probably the wrong watt bulb in there.
Swap left and right side bulbs and see if the bright light follows.
Old Feb 19, 2013 | 08:27 PM
909wheeler's Avatar
Did you replace one bulb?
Always replace bulbs in pairs to keep this from happening.
Old Feb 19, 2013 | 08:44 PM
mtrdrms's Avatar
Man I don't even remember when I changed a bulb last but I only replace them as they blow out. Will swap and see if that works.
Old Feb 20, 2013 | 06:24 AM
drowssap's Avatar
there are 2 brake light bulbs, 5wt 12 vt if i remember i just changed mine a few weeks ago. when you take the taillight lens out there are 6 screws to take the back off and there are 4-5 bulbs.
shaneb24
Jun 17, 2015 09:40 PM
Chrisinhouston
Sep 28, 2013 05:22 PM
Externet
Aug 26, 2013 06:45 PM
nervous4ever
Feb 5, 2009 01:56 PM
mlfore
Apr 8, 2008 03:38 PM
