one of those dumb cdl ???'s
Old Jan 7, 2013 | 01:02 PM
jhill15's Avatar
Default one of those dumb cdl ???'s
There are alot of threads on engaging your cdl if not equipped with the proper h/l shifter, and using a 10mm box wrench on the t case instead. But its unclear to me if and when using this method, do you have to put the transmission in neutral or can it be in park, drive etc..? I am unsure of how this works and I have never locked the diff using a 10mm but just in case I would need to do so does anyone know the answer to this?
Old Jan 7, 2013 | 01:37 PM
lr2001silver's Avatar
Banned
put your truck in park engine off, climb under it and turn it towards the passenger side until it stops get in start it up and your lights should be on! may have to back up and go fpward a bit for it to engage but thats it!
Old Jan 7, 2013 | 01:45 PM
hilltoppersx's Avatar
or keep your truck running, turn it on and have traction control and a CDl. just dont burn yourself on the exhaust.
Old Jan 7, 2013 | 02:34 PM
jhill15's Avatar
So while the engine is running, and in park climb under there and turn it to the passenger side for cdl plus t.c. or turn engine off and do the same for just cdl. Awesome that's what I didn't know. I thought the truck may have to be in neutral like when shifting from high to low gear.
Thanks guys
Old Jan 7, 2013 | 02:50 PM
Shade Tree's Avatar
I think you need to use the open end side of the wrench , not box end.
Just saying.....
Old Jan 7, 2013 | 03:04 PM
or just do this and be done with it https://landroverforums.com/forum/di...install-39541/
Old Jan 7, 2013 | 03:16 PM
jhill15's Avatar
That looks pretty sweet, and way easier then crawling under the truck or spending $500
Old Jan 7, 2013 | 03:24 PM
bballjames's Avatar
I got an 04 style linkage with the shifter plate on ebay for $250. Well worth it in my opinion. Still looks stock and operates flawlessly. Of course I can certainly understand wanting to set it up for under a $100 which is possible... If you are patient though, deals are out there. Especially if there is a Rover graveyard anywhere near you, you might just strike gold... just my $.02
Old Jan 7, 2013 | 03:44 PM
mine was 20bucks. and if i wanted to be fancy i could have gotten a handle to go on it but instead i just used a 1/2" ratchet. it barely came above the rubber mat and it was black...
Old Jan 7, 2013 | 03:48 PM
bballjames's Avatar
Did road/engine noise get considerably louder? That is one of the drawbacks I've experienced with my install. And I even used the shifter plate from the 04, then sealed it with RTV around the sides. It was a lot better than when I first put it in, but still noticeably louder than before I did the install.
