Option B questions
Old Dec 7, 2019 | 12:54 PM
ahab's Avatar
Originally Posted by Best4x4
Internal connector being bypassed inside the wabco unit is the main benefit from Option B.
Oh right, I forgot about the external ground wire setup. That's the true Option B.
Old Dec 7, 2019 | 01:16 PM
Frank4's Avatar
I got the code for a shuttle valve electrical fault. I am going to install this. Thanks for the help
Old Dec 7, 2019 | 02:39 PM
greisinb's Avatar
It’s my understanding that swapping out the shuttle valve switches will not solve the electrical fault. The fault is (almost always) caused by faulty grounding in a circuit board that is not part of the shuttle valve switch (SVS) assembly. I would hate for you to swap out the part just to have the same problem.
1) Remove the old SVS assembly
2) Use a multimeter to measure resistance as the switches are pushed. I forget the exact numbers but it’s something like 3k ohms when none are pressed, 2k ohms when one is pressed and 1k ohms when both are pressed. If your numbers are close then the switches are good and simply replacing the SVS assembly will not solve the problem.
3) Follow the posted instructions to perform the option B fix and be on your way!
Old Dec 7, 2019 | 05:24 PM
Best4x4's Avatar
The black 2 pin plug that connects to the WABCO Unit = where the flaw is. It cracks/breaks up inside on the PCB and will cause the 3 Amigo's whenever it moves from vibration, a bump, hard stop, or whatever. When you cut the yellow/green wire, and then ground it you are 100% bypassing that connection. I personally DO NOT leave the black plug on the shuttle valve switches. I cut that off and run my wires out. I've never had an issue doing it that way.
Old Dec 7, 2019 | 11:25 PM
Frank4's Avatar
this cleared everything up for me. Thanks 4x4.
Old Dec 8, 2019 | 05:01 AM
JUKE179r's Avatar
Hey @Best4x4 do you have pics/website link of totally removing the 2 pin post?
The previous owner of my Disco did the option B as I could tell from the cut green/yellow wire, but I’ve always been skeptical of how he did it since I ever so often get the 3 amigos pop up. Basically, I want to recheck his work.
Old Dec 8, 2019 | 06:31 AM
mln01's Avatar
The link is at the end of my post earlier in this thread.
Old Dec 8, 2019 | 08:17 AM
Best4x4's Avatar
I borrowed this pic from the sticky for ABS fix, but I just pull up on the black plug and then cut off the wires as close to it as possible. Then I make my connections directly to each wire and run them out the bottom. I use the Red/White 2 pin trailer type harness for all my Option B fixes as it's a good gauge wire with a nice durable rubber connector. One end attaches to the Shuttle Valve and the other end connects to the Yellow/Green Wire & a good ground.
Some people have argued that removing the black plug creates an opening for moisture, but I've done it that way for years and years with zero issues!
Old Dec 9, 2019 | 06:23 PM
Frank4's Avatar
Pulled the SVS and the wiring had deteriorated to the point where there was nothing to work with. Insulation was 70% gone and the exposed wires were completely corroded. I mean all the way up to the sealed bases on the switches.
Good news is there was no sign of corrosion in the SVS connection. New switch will be here Thursday, going to install before doing Option B.
Old Dec 9, 2019 | 07:11 PM
Best4x4's Avatar
If the internal connection up inside the WABCO unit is faulty you won't see it unless you totally tear apart the unit. I'd perform Option B and be done with it personally, but you can try just a shuttle valve switch replacement. It's not a hard job to do either way.
