Order has been placed
Old Sep 23, 2020 | 01:20 PM
Best4x4's Avatar
Originally Posted by Motorhead1
So you run without the front cross member Best? You see/feel zero difference? Maybe I will remove mine. More for the driveshaft sake, I've maybe rocked it on one obstacle...idk. Ive had it off already for cat repair
Zero difference on the highway or off road! I drive up to 80MPH and all my D2's feel exactly the same with it removed. If anyone claims it feels different I'd be inspecting your frame for rust lol.
Old Sep 25, 2020 | 04:54 PM
merebel's Avatar
Thanks for the advise. Everything from Lucky 8 has shown up today :-)
And my new tires
275/65 R18 look so big lined up that way with everything stock
Old Sep 26, 2020 | 01:01 PM
04disco2va's Avatar
Originally Posted by JUKE179r
Make sure you spray clear coat on the TF springs and shocks. I wish I did.
Clear coat. Definitely wish I did !!
Old Sep 26, 2020 | 03:37 PM
merebel's Avatar
doing that today and tomorrow next weekend install if weather decent
Old Oct 4, 2020 | 06:46 PM
merebel's Avatar
Well the lift is in the rig :-) wow drives so much better. Still have the old tires on it. And now found out have a front caliper that is funky and the rear ones the slide pin boots need to be replaced. Re greased them all.
took me longer than I wanted. Had to cut the nuts off the sway bar links on 3 of them.
I went with the longer sway bar links too.
deleted the cross bar in the front that made doing the front easier too.
And did clear coat all the parts too.
Old Oct 5, 2020 | 10:43 AM
redwhitekat's Avatar
Looks good. My front shock towers fell apart in my hands when I did mine. Had to get the beefy ones from TF
Old Oct 5, 2020 | 11:17 AM
merebel's Avatar
Yeah that is on the list after new tires and few other things are done
Old Oct 6, 2020 | 03:29 AM
Fanuvkorn's Avatar
Default Just put on the same set up
I put this same set up on minus the sway bar links. Have had some issues with height consistencies. . .
Front passenger 21.25 inches
Rear passenger 20.5 inches
Front driver 20.75 inches
Rear driver 20.25 inches
measured from bottom of flare to center wheel.
I am going to swap front springs to see if it levels it out. I am also thinking about putting 1in spring spacers in to level it out. Any thoughts on that?
Wrangler Duratrac 265/75/16
Old Oct 6, 2020 | 09:09 AM
merebel's Avatar
Mine is level now with this so I know I had a lot of sag in it and now with it done I can see how bad it was. Drivers front shock when unbolted just compressed down all on its own right off the bat. Passengers side did same thing just not as fast.
test fitted front tire on drivers side and ran it through the steering and no rubbing at all :-)
only problem I have is it don’t fit on spare tire holder too tall. I have read where people flip it around but how does that effect the rear wiper blade??
and yeah I need side steps hahahaha
Old Oct 6, 2020 | 11:14 AM
boston4's Avatar
Good looks on the lift! Grab some center caps for the wheels from eBay - I paid $15 for four.
