Is this original front drive shaft?
Check the double cardon universals for grease fittings.
The factory driveshaft has a single "Greasable" Universal joint at the front differential (you posted a photo if this)
The other end (double cardon) is at the transfer case end, this fitted from the factory with non-greasable Universal joints.
Here's a couple of links that may help:
https://landroverforums.com/forum/ge...rebuild-29302/
http://www.discovery2.co.uk/propshafts.html
Thanks everyone, I'll look and post a pic of the double cardon end tonight. I'm sifting through a thick stack of service records (most everything done at LR dealerships) now and logging into a spreadsheet to set the repair/servicing baseline. Yeah sort of nerdy, but invaluable info. Luckily the original owner kept every service record. I've yet to add it all up, but I think SHE almost paid for this vehicle twice!
Yes, not what I hoped
Turns out it is the factory non-greasable version as most of you suggested. The stealership charged $861 for the part alone, it was close to $1k installed..... in 2010.
Looks like I've got a project ahead of me....
Last edited by SmyrnaGuy; 04-17-2015 at 07:23 AM. Reason: corrected year part was installed (not 2000)
