Out of phase front shaft
Old Sep 24, 2010 | 01:45 PM
Jupe209's Avatar
Default Out of phase front shaft
Just had my front prop shaft rebuilt and installed it. Only problem now is some vibration from very slow speeds up to highway cruising speeds.. A constant vibration. Tires are balanced and brand new. Took it to a local drivetrain shop and they can't find anything wrong with the shaft but say it looks like it is out of phase. What is the correct setting for it to be in phase?? A photo or how many splines one way or another?
Old Sep 24, 2010 | 02:01 PM
NiteTrain's Avatar
not sure what they mean 'out of phase' but did they balance it after the rebuild?
Old Sep 24, 2010 | 02:04 PM
Jupe209's Avatar
Nope, individual that rebuilt it had no way to balance it. I got it back and put it back on the truck. Now it is at the local shop that does this type of work. He called me and said he found nothing with it except that it may be out of phase.
Old Sep 24, 2010 | 02:21 PM
lipadj46's Avatar
By out of phase they could mean either you re-installed it in a different orientation or that they did not keep track of the orientation of the 2 halves and they screwed up.
Old Sep 24, 2010 | 02:24 PM
antichrist's Avatar
IIRC the DII front slip yoke is keyed and will only go in one way.
Old Sep 24, 2010 | 02:38 PM
NiteTrain's Avatar
it probably just needs to be balanced
Old Sep 24, 2010 | 02:56 PM
hilltoppersx's Avatar
i think his brain is out of phase. and it needs to be re-balanced.
Old Sep 24, 2010 | 03:27 PM
ROVERTECH15's Avatar
That shaft HAS TO BE BALANCED ASAP!!!!
Old Sep 24, 2010 | 04:06 PM
dcarr1971's Avatar
So, I'm curious about this too. I just rebuilt mine and I was very careful to line everything back up the way it came out. It all feels right at any speeds below 70, but I've noticed a very slight vibration beginning between 70 and 80 mph. It might not even be coming from the front drive shaft, but how noticeable would it be if it needs re-balanced?
Old Sep 24, 2010 | 04:36 PM
yloDiscoII's Avatar
Just stop speeding
