Output shaft speed sensor?
Old Mar 19, 2010 | 11:51 PM
Rickey_240's Avatar
Default Output shaft speed sensor?
Codes displays P0722 Output shaft speed sensor. Anyone know where i can buy one?
Old Mar 20, 2010 | 07:48 AM
Either the dealer or a tranny shop can order one.
Old Mar 20, 2010 | 09:04 PM
Rickey_240's Avatar
Do you know around how much they "should" be?
Old Mar 21, 2010 | 09:41 AM
You'll have to call around and see.
How is your truck shifting, any problems, if so exactly what and have you tried clearing the codes, do they come back??????????????????
Old Mar 22, 2010 | 08:03 AM
Rickey_240's Avatar
9 times out of 10 it will stay in first gear till I hit around 25-30mph then it goes into 3rd gear limp mode. And yes I have cleared the code and yes it does come back. The guy who sold it to me says that he thinks it's something electrical, for my sake i hope he's right.
Old Mar 31, 2010 | 10:03 AM
Rickey_240's Avatar
Question
Any suggestions? What would happen if the tranny was bad? Cause sometimes it shifts through all 4 gears then it will rev like it's in neutral and bang 3rd gear limp mode.
Old Mar 31, 2010 | 10:18 AM
Rickey_240's Avatar
This guy has the exact same promblem I do. Except he didn't specify whether he replaced the speed sensor or the output shaft speed sensor.
http://en.allexperts.com/q/Land-Rove...ver-Series.htm
Old Mar 31, 2010 | 08:21 PM
Urban Panzer's Avatar
Have you tried an oil and filter change ? can make a world of difference to a slush box.
Just for info the output speed sensor :-
ZF PART No is 0501-310-401
Old Apr 1, 2010 | 05:18 AM
Rickey_240's Avatar
yes, i change the oil drove it around then changed it again. i'm gonna do the trans fluid just for the hell of it next.
Old May 5, 2013 | 06:29 PM
mydisco03's Avatar
Hi disco mike.... Today I was off roading with my 2003, and it was on D, I try to go up a hill twice and then the truck went into neutral... I can select reverse or 1 gear. If I take off on 1 gear then D the truck will shift fine, but if I stop, it goes to neutral... any ideas.
