over heating
over heating
I just bought a 99 Disco series 1. I had been driving it 2 weeks, with no problems, when the water pump went out and took the serpintene belt with it. I bought after market from O'Riely and although they just showed 1 pump for series 1 & 2, it seemed the same. Everything seems ok but it keeps getting hot. Am not sure belt is routed correctly but none of the dealers in the area seem to have a diagram. Anyboby have a diagram or any ideas. I have gone beyond fustration and dealer is too expensive for this po boy.
RE: over heating
If the belt is spinning the fan and pump it is probably not a mis-routed belt. I attached a diagram in case you want to double check it. As far as bleeding the air out of the system, this is the most likely culprit. While you are working on the cooling system I would change the thermostat as well for peace of mind.
Cheers,
Pete
Cheers,
Pete
RE: over heating
He has a DI, the belt is routed different. And just because the fan is spinning dosent mean a thing. if the belt is on wrong the fan will spin to slow.
www.atlanticbritsh.com, tech tips.
RE: over heating
http://www.roverparts.com/TechTips/s...g_defender.cfm
After you check your belt routing and it is good then you will need to bleed the system.
If you need help with that just ask.
RE: over heating
Start on level ground.
With the engine cold, remove the cap from the coolant resovoir and the plug from the top of the radiator.
Make sure the radiator is full and then the resovoir is to the correct level.
Start the trk and put both sides of the HVAC to HOT, turn the HVAC fan on low, if you put it on "dash" and open the drivers window it will be easier.
Let the engine idle making sure that the radiator is kept full. Every once in awhile stick your hand inside the window and feel for hot air coming from the vent.
Once hot coolant starts to come out of the hole in the top of the radiator in a steady stream replace the plug, leave the engine running while you do this.
Now keep the colant bottle at the proper level at the same time.
Once steam starts to come out of the coolant bottle replace the cap.
You are done.
Check the coolant level once a day for the next two days after it has sat overnight.
You are done.
