Over heating issues disco 2
Old Oct 3, 2021 | 03:56 PM
Maxwell_land's Avatar
Default Over heating issues disco 2
Trying to figure out what to do my disco 2 over heated and **** off now every time I turn it on it heats up quick and the temp gauge isn't working
Old Oct 3, 2021 | 04:01 PM
cvhyatt's Avatar
Not enough info to go on as you didn't provide a lot of detail. Get a code reader and check for codes then let us know what you find.
Old Oct 3, 2021 | 04:47 PM
Okay this just happened and dont have a code ready was just trying to see if there was any general info for a way to start diagnosis but thanks
Old Oct 3, 2021 | 05:15 PM
Harvlr's Avatar
If you overheated you probably blew out a lot of coolant. Have you bled all of the air out?
Old Oct 3, 2021 | 06:46 PM
Extinct's Avatar
Two possibilities:
1. Actually overheated. If it happened suddenly and fast, likely a stuck thermostat. If the thermostat is stuck the passenger side radiator hose will be relatively cool, radiator end tank to, top radiator hose a bit warmer but still relatively cool. Check the inline thermostat mod sticky at the top of the forum.
2. Did not actually overheat, bad sensor. If you have an IR gun you can check the heater hoses to see how hot they are. Buzz the engine to 1500-2500 while checking.
Did it boil over?
Old Oct 3, 2021 | 07:11 PM
Yes it did boil over and **** off also when I start it it starts boiling kinda quick I dont have a temp gun but I was thinking thermostat as well I guess I will start there or try to bypass it to see if that helps first thanks
Old Oct 3, 2021 | 11:38 PM
Richard Gallant's Avatar
@Maxwell_land How fast does it boil over, it takes mine about 15 minutes under load to get to 183ish and that is thermostat closed. I had a stuck thermostat, took almost 20 minutes to hit over heat with an open cap, I was lucky.
Faster than that is likely a bigger issue
Old Oct 4, 2021 | 02:32 AM
Extinct's Avatar
I have seen them take less than 5 minutes. Gone to drive trucks and can't even make it around the block. Almost always stuck thermostat if it overheats fast.
Old Oct 4, 2021 | 07:16 AM
mollusc's Avatar
Also note that the temperature gauge on the dashboard doesn't tell you anything even when it does work. It basically has three positions: cold - running - too late.
Old Oct 4, 2021 | 10:39 AM
redwhitekat's Avatar
How does a shop know if it’s a cracked block ? Or head gaskets
