Over heating issues disco 2
Old Oct 4, 2021 | 11:20 AM
Maxwell_land's Avatar
I hope it's not a bigger issue I will order the thermostat this friday and replace it but it takes about 5 mins running at dollar to start boiling over the temp gauge does nothing now
Old Oct 4, 2021 | 01:35 PM
Externet's Avatar
Hoping diagnoses nothing, guessing it is a thermostat diagnoses nothing. The dash thermometer does nothing and never did by design.
5 minutes to boil needs compression testing to find if head gasket is bad. Instant 'boiling' after start may not be actual boiling but exhaust gas getting into the coolant. An uncapped coolant reservoir can tell that.
Old Oct 13, 2021 | 06:51 PM
Update I did a compression test and all is good as far as that so the thermostat is in the mail thanks for the help
Old Oct 14, 2021 | 10:52 AM
Externet's Avatar
Good.
Not telling to do it, but if I were you, would totally eliminate the thermostat by hooking a hose directly from the lower radiator outlet to the coolant pump suction and engine outlet to radiator inlet discarding the bypass hose.
If your new thermostat disappointingly behaves bad when installed, come back.
Old Oct 14, 2021 | 10:57 AM
thebilgerat's Avatar
Dunno if anyone mentioned it but if you're dropping the money for new T-stat now is the time to do the Extinct tstat mod. Its where you're going to end up anyways so may as well be now
Old Oct 14, 2021 | 12:37 PM
Richard Gallant's Avatar
@Maxwell_land A good compression test only eliminates bit head gasket failures, small crack related failures that open only after warmth will pass a lot of the time but still over-pressure your cooling systems.
My head gasket failure would have passed a compression fine, cold. But I never over heated, just over pressured.
Old Oct 14, 2021 | 03:03 PM
No one has what is that
Old Oct 14, 2021 | 03:19 PM
whowa004's Avatar
https://landroverforums.com/forum/di...thread-105010/
money very well spent.
Old Oct 14, 2021 | 09:37 PM
Thanks for the info it was a good read but I am tight on money at the moment and am trying to cover a variety of little issues at the moment down the road I will be sure to make these necessary adjustments
y2kdisco
May 21, 2021 08:44 PM
Fitzy250
Oct 15, 2011 06:41 AM
LRScott
13
Apr 7, 2010 02:26 AM
LRScott
Jun 10, 2009 07:26 PM
rightsandlefts
May 7, 2009 10:25 PM
