Overall effect of larger tires and wheels?
Old Mar 10, 2015 | 09:49 AM
film842's Avatar
Default Overall effect of larger tires and wheels?
I've researched this issue, but haven't been able to sort out a clear answer.
I assume that owners install 18 inch wheels and large tires to gain ground clearance, but my question is: what does that do your vehicle otherwise?
Do larger wheels/tires impact gas mileage and what does it do to general drive-ability? Is the vehicle any less safe on the highway, etc?
Old Mar 10, 2015 | 10:00 AM
dusty1's Avatar
16" rims are usually desired with the larger tires. more rubber
mileage will suffer as your little v8 is working harder.
a change in gear ratio is advised if you go big enough. most guys do 4:11 with 33s
safety and drivability are easily maintained. you will notice some things more and some things less. for example; a bent axle on 29" tires might never be noticed. throw some 35's on and it looks like you are about to lose a wheel. you will need to assure that you brake lines and components match your lift
Old Mar 10, 2015 | 10:15 PM
T.J.'s Avatar
Expect mods like bigger tires, roof racks, winch bumpers and suspension lifts to increase fuel consumption. I notice more wind and tire noise, but no noticeable effect on safety.
Old Mar 11, 2015 | 09:36 AM
film842's Avatar
Thanks for responses. That's just what I needed to know to make a decision on new tires.
I don't want to affect my gas mileage adversely and since I already have a two inch lift from new medium duty TF coils and shocks, I think I'll stay with my 245 75R16 tires and call it good.
Plans include some long distance road trips in the next couple of years and mileage is definitely an issue. Plus we'll be pulling a small offroad trailer, so...
Old Mar 12, 2015 | 02:59 PM
Richard Moss's Avatar
The slightly bigger tyres on my D2 raise the gearing slightly so that it revs slower for a given speed, making it a bit more refined (in theory). It also means that my speedo now over reads slightly so I need to be careful about speed limits (100km/h on the speedo gives me 103 according to my sat nav)
Old Mar 12, 2015 | 04:16 PM
OffroadFrance's Avatar
x1 this is one main feature of larger tyres without diff ratio compensation as the speedo under reads actual true speed but being the standard speedo/tire setup reads between 5-10% faster than actual ground speed (by law) it is unlikely to be too far OTT. It can be calculated easily with the use of a satnav as Richard has stated or simple math. The other downsides are lower MPG and higher CoG also a worsening of highway handling at higher speeds (over 60mph) plus any tire imbalance is magnified somewhat. Road noise will increase anyways using AT or even chunkier tires over the standard highway tires so additional wind noise won't be significantly noticeable.
formel3
Jan 27, 2014 05:26 PM
product
Jul 26, 2012 08:02 PM
rdiaz
16
Nov 4, 2008 07:59 PM
Prepilot_3ck
Jul 27, 2006 06:35 PM
nick1996rover
Mar 7, 2005 08:37 PM
