overheating 2000 Disco Series II TD5
Old Sep 25, 2014 | 08:22 AM
Jamie Telford's Avatar
7th Gear
Default overheating 2000 Disco Series II TD5
Hi all!
Sorry to make my first post about a problem I'm having with a 2000 Series II Discovery TD5, but here I am!
I've read around a bit in an attempt to research the problem. With the following thread giving a good check list.
However I'd like to run the problem by you guys for any extra info.
Basically the Disco is overheating very quickly now and appears to be boiling off/discharging water through the over flow.
The following is the chain of events
  • I drive about 100km and then the temp starts rising dramatically and finally peaks. The vehicle also loses power (electronically controlled??)
  • I immediately pull over and idle the engine, opening the bonnet and the check the levels.
  • The fan is running full tilt and the header tank level is almost empty and steam is blowing out from the cap.
  • After the engine has run for about 5 minutes the temp has stabilised and the fan switches off.
  • I'm able at the point to unscrew the header cap to top up..
    I partially unscrew it (not take it off, just to release pressure)
  • at this point the cooling fluid rushes back into the header tank, I screw the lid down hard again.. and the header tank level drops to almost nothing again.
  • I repeat these steps a couple of times until at some point the coolant ceases to flow back in the header tank.
  • I'm then able to top up the fluids and drive off carefully again.
The car seems to be functioning perfectly apart from this..
any additional help/tips would be appreciated.
p.s. I'm on the road in Montenegro and need to do some kinda stop gap repair.
Old Sep 25, 2014 | 08:55 AM
jafir's Avatar
This forum is populated by MOSTLY people in North America, and there are just a handful of TD5 here, mostly in Canada now that they are 15 years old and eligible for import. While some of our members might be able to help with basic troubleshooting, you'd get faster, more applicable help from a forum populated with users that were able to buy TD5 when they were new. I'd suggest a forum in the UK or Australia. The Australian Land Rover Owners - AULRO.com is a great forum with lots of helpful people.
Old Sep 25, 2014 | 09:01 AM
7th Gear
Sweet bro! thanks for the tip!
Old Sep 25, 2014 | 09:35 AM
drowssap's Avatar
don't be surprise if it is a cracked head on a TD-5
Old Sep 25, 2014 | 09:45 AM
7th Gear
kinda prepared with the worst.. but hoping for something simple.. will check to see if there is water in the oil later today.
Old May 6, 2020 | 02:32 AM
Chris Bradley's Avatar
3rd Gear
I'm keen to see how you go man I have the exact same problem overheating after say an hour or just over and I've replaced water pump, thermostat, hoses, flushed system, new coolant had a mechanic bleed it every time and it still overheats on long drives
Old May 6, 2020 | 02:34 PM
7th Gear
5char
Old May 6, 2020 | 02:45 PM
7th Gear
Yup... I traced the problem to the fan assembly itself.. It has some kind of viscous fluid clutch which operates in a temperature range.. This wasn't working as designed (fluid drained out? Or went bad?) I ended up using cable ties to lock the fan (plastic part) to the clutch shaft part.. After this no more overheating.. Working!
I'm sure this field fix would cause problems in cold climates, but it kept us on the road for that trip.. Was tricky to diagnose as the fan was always spinning.. Just not actually spinning at the same speed as the motor..
Hope that helps!
Old May 6, 2020 | 08:38 PM
3rd Gear
I'll give it a go, did you have to do any long term fixes and any chance you have pics ? 😄 Thank you so much for replying
Old May 6, 2020 | 10:02 PM
Richard Gallant's Avatar
@Jamie Telford Glad it was something simple and that is the is the issue with clutch fans figuring out if they are working they tend to alway spin, but as you discovered they may not lockup.
