Overheating
Old Jun 25, 2019 | 11:07 AM
  #21
Dan7's Avatar
How does taking the belt off diagnose if it’s in good condition?
Old Jun 25, 2019 | 01:51 PM
  #22
redrover75's Avatar
I was driving pretty aggressively in city traffic last weekend, mid 80s, and the gauge went about 75% of the way up until I turned off the AC and drove modestly until it was back to normal. I run the low temp tstat, new fluid, water pump, everything except the radiator. Doubt it is original.
yesterday, after some short driving, the aux fan stayed on for another 20 min after shutdown. First time that has happened in a long time, only mid 80s temp.
I should probably look into it.
Old Jun 25, 2019 | 08:13 PM
  #23
Dan7's Avatar
You need an ultra gauge or other real time OBDII temp reader. At 225F, The stock temperature sensor won’t budge from dead center, so you were somewhere over that.
Old Jun 25, 2019 | 10:57 PM
  #24
discoaintdead's Avatar
7th Gear
I have this device that show the temp. It connects to the readout connector. Works really well. If any of would like details i can take a pic during the day with the manufactuerer and model number.
Old Jul 24, 2019 | 03:26 PM
  #25
Dan7's Avatar
OK, so I’ve replaced the coolant reservoir cap and thermostat and flush the system with no change. I think the next step is replacing the electric fan which I think just can’t keep up. Any recommendations as to where I could screw in a temperature sensor? I have secondary air so I can’t use that port on the radiator unless I get a T fitting or something.
Another option is to use the petcock screw from the in-line thermostat mod. If I remove the screw it should be able to fit a temperature sender. But I would lose the option to bleed the cooling system from that point which has been handy but not a requirement. Thoughts?
Old Jul 24, 2019 | 03:46 PM
  #26
Richard Gallant's Avatar
@Dan7 If you have an android phone, download the Torque app and buy one these
Bluetooth code reader Bluetooth code reader
any one you want really. And you can monitor your temps cheap. Iphones are squirreler but it can still be done
Old Jul 24, 2019 | 04:58 PM
  #27
Dan7's Avatar
I have an iPhone, and an ultra gauge but thanks ... I hear that’s a great option
Old Jul 24, 2019 | 05:19 PM
  #28
mln01's Avatar
Again, the fan has nothing to do with cooling at highway speeds. The problem is either an inefficient (i.e. clogged) radiator, a water pump that's not pumping well enough (highly unlikely) or the thermostat.
Old Jul 24, 2019 | 05:52 PM
  #29
@Dan7 Sorry I mis-understood.
A few things I have found on my 04 :
  • proper fitting of the radiator shroud all the way around matters - my lower clips were undone fixing that dropped my temps by 5 Deg F -down to 183 ish for 188 ish
  • A functional AC electrical fan helps but only if you have the AC running. My wife and I went for a drive, she likes AC and I actually heard the fan running when I got out to move a largish downed branch. If that fan is non functional and you run AC you will run hotter
  • It could be your electric fan as the brushes wear they become less efficient, but I would think an automotive fan would be good for 5+ years easy
  • I run the dorman / hayden setup and have very few issues
Old Jul 24, 2019 | 10:31 PM
  #30
Saturnine's Avatar
Just drill and tap another hole for a sender unit
