overheating disco
overheating disco
hello, i got a 2001 disco, i just replaced the radiator 2 weeks ago because i broke the other one mudding, it start overheating so i i check the fan clutch and it was bad so i decided to replace it with an electric one, it works fine, it does not overheat while driving in the city, but ones i drive it in the highway and stop it does overheat, also im getting a code that says catalytic damaging, any ideas??? please help is driving me crazy!!
it has 96000 miles, the weird thing is that i can drive it in the city with out trouble but went i jump in the high way and i exit it is went it overheats, the electric fan is working fine with a thermostat, i have not change the radiator thermostat, but it seems to be working, and the codes that im getting are catalytic damaging, oxygen sensor bank 1 and catalytic damaging misfire piston 8,4,2. im going to take the catalytics off monday and see what happens!
sorry, im new to this so i post it in the wrong place the first time! tomorrow im checking what codes im getting, i took out the intake because i found out that i had a leak in the intake, is running a lot better and the check engine is not flashing anymore, also i found that i had a coolant leak by the throttle body, the only problem is that one of the bolt broke trying to take it off, so i bypass it until tomorrow that i can get it fix, it is ok to drive it like that till tomorrow?
