Overheating issues
Old Jul 21, 2020 | 06:18 PM
  #21
Oasisplayer311's Avatar
Originally Posted by Extinct
I can confirm that side goes toward the radiator.
Thanks!! It weird to me that the thermostat opens towards the flow vs away. But I don't know much about cooling systems lol
Old Jul 21, 2020 | 09:12 PM
  #22
So im now getting worse temps then I did when it way faced the opposite way! AHHHHH! Does anyone know how to properly bleed the entire system of air? This thing has become such a headache
Old Jul 22, 2020 | 10:45 AM
  #23
redrover75's Avatar
I think the most fool proof way to bleed is with a vacuum bleeder. I have had good luck just pulling the reservoir out and holding up, as high as you can, and bleeding that way. Although I just installed an inline from Extinct that works great with out bleeding, just filling it up via the hose and then filling the expansion tank.
any chance your sensor is giving you bad info?
Is the new radiator working? with an IR thermometer are you getting predictable temps? Hotter near the input, cooler near the output?
Can you squeeze the hoses when it is running, or hot? do they collapse? under vacuum? do the hoses feel uniformly firm?
Old Jul 22, 2020 | 12:52 PM
  #24
whowa004's Avatar
I've never had any issues just raising the reservoir...has worked first try each time I've needed to bleed my systems.
jdwilks
Sep 1, 2014 09:41 AM
rovingmad
Sep 10, 2013 09:05 AM
Savannah Buzz
Jun 16, 2011 09:20 PM
Savannah Buzz
May 12, 2011 09:08 AM
alanski
Jun 13, 2008 11:16 AM
