Oxygen Sensors for Disco II
I have been told that I should replace all 4 of my O2 sensors. My Disco II has 110k on it and is showing a check engine light.
Last weekend I looked under the hoodand I could see two sensorsthat look easy to remove and replace. Can anyone tell me where the other two sensors are located?Sorry to ask, but I am out of town on business and my DII is at home so I can't crawl under it to see check if they are visible from below.
Also, I am assuming that I need to order two of the front sensors (MHK100920)and two of the rear sensor (MHK100930)?
Once these are replaced do I need to have the errors reset, or will they go away with replacement of the sensors?
Is replacing these an easy process, or should I have my mechanic replace them?
Thanks for any help!
RE: Oxygen Sensors for Disco II
You can replace them, 2 in front of the cats, 2 in back. Crawl under the truck and you'll see them. You can do it your self, a few are tougher to get to supposedly. Haven't had to do mine yet. Everyone recommends you do all 4 at the same time though. As for the codes, someone else may chime in, not sure on that one.
