ok this code is starting to bug me
Po replaced o2 sensors
has anyone got a definitive fix on this code
reading about it no one seems to really pin point what their fix was ???
they have heat shields. You may try the old vacuum to the tailpipe truck. For me I could hear the leak under engine load. I removed the y pipe and demmeled the heat shielding off and sure enough the weld was toast
