P0101 and P0505
Old Mar 21, 2013 | 12:52 PM
Rovin Rovers's Avatar
He is pretty amazing and knows the Land Rover well. So glad you found us and just in time too!!
Old Mar 21, 2013 | 04:09 PM
jfall's Avatar
Can someone show us this part to help us learn..
It was the reduction valve/metered air baffle on the valve cover PCV port.
So, that is the square part in side of the Valve Cover?
Is yours plugged - or getting TOO much air.
Would think it may have been sucking in too much air from the engine and that is getting around the MAF?
Then if a valve cover gasket is bad - and it is sucking air from the outside from under the valve cover gasket and thru the
Old Mar 22, 2013 | 12:17 AM
Default Pcode 0101 MAFS air sum error
This is the oil separator valve that also meters air for the fuel injection Oil Separator - Valve Cover (Part # LLJ000010) - Land Rover miscellaneous from Atlantic British
I installed it in the Rocker Cover. Check PVC ports. If there is not anything in either, put one in one of the ports. In stock (US model) it is on the passenger side port, opposite side of the throttle body.
It was not the original valve cover gasket to the the car. I put that oil separator in there to duplicate what the reduction valve in the stock valve cover does.
Cheers, Emily & Jahn
Old Mar 22, 2013 | 02:59 PM
durry707's Avatar
8th Gear
subscribed to thread
this fixed those codes/ i have some of the same issues i have a thread already but like to get more info.
Trans96am
Nov 22, 2024 09:16 AM
diftspec
Oct 14, 2014 10:59 PM
Robert Booth
Mar 21, 2013 12:48 PM
RegT
May 10, 2010 09:50 PM
