P0130, 0171, 1171
P0130, 0171, 1171
Got these codes saturday when I was out of town. I just happened to have my reader with me, and erased the codes. They came on again yesterday.
I've searched and found a post earlier this year leaning towards o2 sensors, plugs/wires, and MAF.
The MAF and plugs/wires, have been changed within two years(20000 mi). I always run 93, and have a fram air filter from autozone.
If the o2 sensors need replacing,isthere any problem going with aftermarket? ( i'm broke).I'ma marine electrical tech, sothe connectionswill never be a problem, just wondering about the actual sensors.
RE: P0130, 0171, 1171
As long as they are for your LR you will be fine.
What O2's are you looking to get?
http://www.roverparts.com/Parts/MHK100930.cfm
I really dont think you will beat this price, but I might be wrong. $60.
The rear O2 sensors are there to determine if the catalytic converter is working or not. The front O2 sensors are used in the closed loop fueling process (versus open loop operation).
http://www.samarins.com/glossary/oxygen_sensor.html
Cheers,
Pete
Cheers,
Pete
ORIGINAL: tacomatech
Definitely check for vacuum leaks as well, smoke test if possible. I had one with the same codes repeating, ended up finding a leaking throttle shaft(wasn't detectable through artificial enrichment using throttle body cleaner, barely found by smoke testing).
