P0134 and P0305
Old Jan 6, 2015 | 11:36 AM
cybercop's Avatar
Originally Posted by Yoops Racing
The whiring noise is 100% normal.
the code could be because one of the mounting points came loose from the Sec Air hoses. Same thing happened to me.
Before ordering MAF and o2 sensors have you spoken to David at The Shop? You may not need these
Not yet. I planned to call John this week. I fixed the whirling sound. What mounting points are you talking about?
Old Jan 6, 2015 | 01:44 PM
OverRover's Avatar
Originally Posted by cybercop
Are these direct plug in, or do they need to be modified at the connectors? Are they just as good, if not better than the Bosch?
Just talked to Tech @ NTK and re: Amazon... they might have connectors, or not. But from authorized NTK vendors #25623 and #25624 always have the connectors.
Rockauto has them for still under $200 for 4 > $50.99 and $47.89.
Maybe someone who bought these from Amazon can give you more info.
As far as quality, I only use NTK O2 sensors/NGK Plugs on all my cars. I haven't had good results with Bosch in years.
Old Jan 6, 2015 | 01:47 PM
ROVERRACER's Avatar
Default Maf
I bought a used MAF sensor. Works fine.
Old Jan 6, 2015 | 05:43 PM
cybercop's Avatar
So replacing the MAF sensor specifically fixed these codes?
Old Jan 9, 2015 | 09:55 PM
cybercop's Avatar
Well, problem turned out to be O2 sensor on left bank (drivers side) AND water throughout the entire secondary air system, even in the check valves.
How do you suppose water got into the secondary air system? It was even in the pump.
smittyrc
Dec 23, 2013 08:37 AM
RSPTex
Nov 24, 2013 01:41 PM
jnice
Jun 28, 2008 09:38 PM
