P0137 & p1170
99 D2 140,000 miles.
P0137-o2 Circuit low voltage (bak 1, sensor 2)
P1170- Lambda sensor aging tv bank 1Drive cycle C:Signal out of range - above maximum / below minimum
have relaced all four o2 sensors, and had ecu looked at and some connections remade. that solved a lot of problems, now im getting these codes... tring not to take it to the dealer
I am still getting these codes... they came up shortly after a brake job, i know this has nothing to do with brakes, it just seems that after i do anything they come up.
Question is: if I have an exhaust leak, would these codes be related to the exhaust having a leak at the cat.?
Unless i can get pointed in the right direction here....
