P0150
Old Jul 20, 2009 | 04:53 PM
TOAD's Avatar
Default P0150
This is the code I'm getting from my obd2 reader and I've changed the front 2 o2 sensors, plus have changed the Mass air flow sensor within the last 2 years. I bought bosch o2 sensors, do you think one of them is defaulty? 94k miles maybe the back o2s need to be replaced?
Old Jul 20, 2009 | 05:06 PM
Replace the back ones too.
Then reset the code and see if it comes back.
Also double check your work on the front ones.
Old Jul 21, 2009 | 08:55 AM
If you had read your code properly you would see that a 150 is a circuit malfunction on the front 02, passengers side.
You should have replaced all 4 at the same time.
hriant88
May 27, 2008 09:06 PM
hriant88
Apr 30, 2008 07:33 AM
wooz797
Apr 5, 2008 09:04 PM
robdis96
Jul 5, 2007 01:02 PM
