p0150 code b2s1
Old Apr 5, 2008 | 06:02 PM
wooz797's Avatar
Default p0150 code b2s1
code reads a (o2 sensor circuit bank 2 sensor 1) is that code implying a fault in the circuit or a high or low value. fuel trims bank1 long ft 6.23 short ft 2.34
bank2 long ft 6.23 short ft -2.34
these were the freeze frame values
trying to determine if it is a circuit problem or fuel problem. long term ft are the same but somewhat high, maybe an air leak past the maf sensor. any ideas anyone
thanks
Old Apr 5, 2008 | 07:28 PM
Default RE: p0150 code b2s1
Need the year and mileage of the trk.
Old Apr 5, 2008 | 07:33 PM
wooz797's Avatar
sorry 1999 discovery 1 133,000 miles, passed emissions i CO and light came on the next day
Old Apr 5, 2008 | 08:53 PM
I would have to say bad O2 sensors. What sucks though is that you have 4 of them and you cant just replace one, you must replace all four.
At least you passed inspection though.
Old Apr 5, 2008 | 08:59 PM
wooz797's Avatar
yeah i think ill replace those O2 sensors, I always assumed that they dont normally just go bad. I'm just curious if the bad sensor is just a symptom of a larger problem. Of course 130k on the original sensors seems likely they are just old.
Old Apr 5, 2008 | 09:04 PM
They wear out around 60-70k and then fail around 80-90k.
kae
Mar 4, 2023 12:18 PM
deltbro
Mar 13, 2013 12:04 PM
gchillog
Feb 22, 2011 04:53 PM
sorusty
Dec 17, 2010 12:16 PM
hriant88
Apr 30, 2008 07:33 AM
