P0170 Code help
Old Feb 29, 2012 | 08:58 AM
FightOnUSC79's Avatar
Cleaned connectors on Pre-cat o2 sensor and the code is back P0130, and knowing all four sensors are only a year old I'm guessing it may be something else. Would this be something the MAF could cause?
Old Feb 29, 2012 | 09:08 AM
Ad!'s Avatar
Ad!
Your sensor isnt working, you can't clean o2s. I suggest replacing the part but totally up to you.
Old Feb 29, 2012 | 10:15 AM
Meant I cleaned the connector at the plug, so do O2's go bad after a year?
Old Feb 29, 2012 | 11:47 AM
discotheque's Avatar
they can if you had coolant leaking on it for some time
or if you bought cheap quality a year ago
Old Feb 29, 2012 | 11:52 AM
It started after my Throttle body heater went and it did dump coolant on the precat sensor.. Not what IO wanted to hear, but I guess I'll replace again and see what happens.. When I did the maintenance i replaced both front and rear per Land Rover, and used the following.
Oxygen Sensor - Rear
Item: MHK100930
In Stock: Yes!
Fits:
Discovery Series II | '99 - '04
Range Rover 4.0 (P38) | '99 - '02
Range Rover 4.6 (P38) | '99 - '02
Freelander | '02 - '05
Our Price: $69.95
Qty
Oxygen Sensor - Front
Item: MHK100920
In Stock: Yes!
Fits:
Old Feb 29, 2012 | 02:08 PM
Ad!'s Avatar
Ad!
My truck had those before i replaced them with bosch o2 sensors. Do you know what brand the front o2s are from roverparts?
Old Feb 29, 2012 | 02:16 PM
Not sure, but I'm going to find out the warranty on them to see what I can get done.
Old Feb 29, 2012 | 05:40 PM
Now I've got the P1070 and P1171?? After a search I'm finding this is probably the MAF, as I cannot find a vacuum leak like some of the threads said to check for? Is there a way to confirm this without purchasing a new one and trouble shooting with part in hand?
Old Mar 1, 2012 | 10:17 AM
P0171 continues to pop, so I am under the suspicion this is the MAF in itself? No leak in Vac lines that I can find, but before ordering new MAF would love a 2nd opinion from the forum.
Thanks
Old Mar 5, 2012 | 01:06 PM
Ad!'s Avatar
Ad!
Did you try cleaning your maf? I had p0171 p0174 p0733 p0734 before I cleaned my maf, cleared codes and they haven't been back since. Good way to see if your maf is bad. Remember to clean only when cold. Crc maf cleaner works great.
