P0171, p0174
Old Jan 13, 2015 | 11:00 AM
kodiesgrampy's Avatar
5th Gear
Default P0171, p0174
I have a 04 Disco II, getting the codes 171 and 174. It idles ok, and up to like 30 MPH, once I get above 30 MPH and 1500 RPM there seems to be a (for lack of better term) a shake, but if I back off the accelerator, the shake goes away. Any ideas of where/how to troubleshoot? Thanks.
Old Jan 13, 2015 | 11:29 AM
dusty1's Avatar
1st guess is Vacuum leaks (that's what mine was)
or
Maf issue.... Filter box good?
Old Jan 13, 2015 | 01:36 PM
OCMike's Avatar
Mine went away after fixing a vacuum leak and replacing the air filter. Or, at least it hasn't come back yet.
Old Jan 16, 2015 | 02:04 PM
sdhow's Avatar
Where specifically were the vacuum leaks? I'm getting PO130 and PO171 after doing the manifold gasket replacement. Noticed some rubber vacuum connectors with tie wraps on them; are some more likely than others to leak? Should I use O-Ring lube on these to create a better seal?
Old Jan 16, 2015 | 02:16 PM
dusty1's Avatar
mine was injector seal.....not related to a repair. any that you were leaning/pulling on.....start with the brake servo
Old Jan 16, 2015 | 02:34 PM
sdhow's Avatar
Well, that would be ALL of them, given that the whole upper and lower intake was off!
Old Jan 16, 2015 | 02:55 PM
dusty1's Avatar
oh, intake manifold.
look at the brake servo anyway.
Old Jan 17, 2015 | 09:56 AM
mark d's Avatar
Mine was injector seals
Old Jan 18, 2015 | 06:34 AM
5th Gear
Default Half way there I think
Did smoke test with cigar, found 2 places where there were leaks, fixed them. Running better but not perfect, should I replace the MAF?
Old Jan 18, 2015 | 10:36 AM
bmeier's Avatar
Have you tried to clean (MAF) it first?, did mine when I first got the truck, no code since.
