P0174 Code Help
Old Nov 13, 2018 | 12:43 PM
DiscoveryIIPhil's Avatar
Default P0174 Code Help
I am getting a code P0174 for system too lean Bank 2. Is this an injector issue or O2 Sensor failure? Or is it something else entirely?
I'm about a green as it gets with these vehicles so please forgive my ignorance.
TIA,
Phil
Old Nov 13, 2018 | 05:31 PM
LR03NJ's Avatar
Try 2 bottles injector cleaner first for a 1 full tank if pemium. Then reset code.
Old Nov 13, 2018 | 08:01 PM
Richard Gallant's Avatar
Check your intake system for leaks, in particular the primary intake hose from the air cleaner to throttle body and all attached hoses. The one that comes off near the throttle body is prone to cracking and leaking.
Old Nov 13, 2018 | 08:20 PM
redwhitekat's Avatar
I had the same issue Mine was the fuel purge valve Research that. There is a Hyundai part number it's easy and cheap to replace
mirepoixmatt
Oct 11, 2019 12:46 PM
Jared Burns
Feb 1, 2019 09:37 PM
redwhitekat
Apr 20, 2018 07:01 PM
mordor110
Mar 15, 2011 06:55 AM
DeepBlueWater
Jan 31, 2009 04:17 PM
