P0335 discussion
Old Jul 25, 2024 | 10:10 AM
treicruz's Avatar
Default P0335 discussion
Hi all,
as my last post mentioned, I recently did head gasket job. While I was in there I replaced a bunch of parts. Front Cover, ignition coils...etc most important to this next story is the timing chain kit. New gears / chain.
All has been well so far, minus a oil leak, until my drive home yesterday. The car completely died, flashing M and S and (D) on the gear selector, where the mileage shows. Pulled over, turned off, turned back on got home. Code P0335 thrown so I investigated a bit and found that maybe it's a bad CKPS due to oil getting on the connector, but I'm also questioning if the "AllMakes4x4" timing kit was worthless and messed up my timing slightly?
Either way the car is parked right now until I get my new CKPS in. Just wanted to have a discussion to what might be causing this or if anyone has had the issue with bad timing = ckps code thrown.
Old Jul 25, 2024 | 08:27 PM
mln01's Avatar
Why not try some CRD QD Electronic Cleaner or QD Contact Cleaner before committing to a new CKPS?
After all, if the problem is oil in the connector that may affect the new CKPS too.
Old Jul 26, 2024 | 12:05 AM
JohnZo's Avatar
Do you have the code definition? Also wondering how much you sold the '03 for, and when?
Old Jul 26, 2024 | 07:22 AM
WaltNYC's Avatar
"P0335 Crankshaft position sensor a circuit malfunction
Reference mark outside search window for more than two revs, with engine speed above 500 rev/min"
check the google drive for the manuals in pdf which are easily searchable (ctrl+F)
sut123
LR4
23
Dec 23, 2024 12:07 AM
me 2
Aug 12, 2021 07:02 AM
robert.juric
Jan 9, 2017 06:52 AM
za105
Apr 6, 2016 02:38 PM
DooDer
Jan 1, 2010 02:26 PM
