P0451 - Fuel Tank Pressure Sensor Signal Error Fault
Changed out my fuel pump this weekend and now am getting a P0451-Fuel Tank Pressure Sensor Signal Error Fault. I only changed the pump, not the housing which contains the fuel tank pressure sensor. I'm gonna pull the carpet up tonight and make sure the connector is tight and that the vent hose is snug. Other than that, anyone have any other ideas on what might be causing this.
Interesting. That makes me wonder if not tightening the metal retaining ring for the fuel pump would do the same thing as not tightening the fuel cap.........Maybe I'll tighten that a little more when I pull the carpet back.
I have this same code. Did anything you do fix the problem? I know this post was from years ago..lol But just wondering so I know what I am dealing with. Thanks!
I guess ill give it another go at bring up an old post. Well I am all over the place trying to get rid of my last code. its the same Pressure Sensor Signal Error Fault. I got to opening up the cover and found that the vacuum hose that went up towards the fuel tank filler had broke so I replaced that. cleared code and reset adaptations and the code still keeps coming back. I am trying to test the wires to see if there is a problem with the sensor or the wiring up to the sensor connector. I get power onf the solid red wire. how can I go about testing the whole sensor itself? I may just go try to pick up a whole fuel pump from the junk yard and hope its the sensor in the fuel pump but my wires were also exposed and the green wire sheild was broken a little so I'm worried its the wiring up to it and not the sensor itself.
ChrisW329,
Can you tell me where the line goes from the tank pressure sensor? Is this a vacuum line to the filler cap or to the charcoal canister. My understanding is that this sensor compares values to the filler tube pressure sensor during an evap test.
I am having the same code. Come to find out there is no vacuum line of the fuel tank pressure sensor. Can someone enlighten me as to where the line should go for the fuel tank pressure sensor?
