P1300, p1319, p0304, p0307
I am getting these codes under heavy acceleration. P1300, P1319, P0304, and P0307 in different combinations.
I am going to do a can of seafoam in the gas, induction cleaning, and check the spark plugs, wires, when weather permits.
Anyone had a similar experience? I can drive around town no codes, but if I put the accelerator down the codes pop up. I was thinking possible vacuum leak or air filter, but everything looks OK.
The 1319 relates to low fuel level, so maybe clogged injector?
Filled up, put seafoam in the gas, did an induction cleaning. I have got to do it early in the morning next time. I was getting lights flashed at me, as she was smokin' like crazy.
Got codes of course, but cleared them and none came back. Will monitor from here.
This was my first time doing it, so maybe I will do it again when I change oil. I was surprised how quickly she gobbled up the Seafoam. I was always kind of ciscouraged, because I don't have a fancy valve system set up to meter it, but that would just be a waste. Just need a locking pliers.
Just in case you did not see this.
https://landroverforums.com/forum/ra...4-p0307-57815/
Maybe the shared coil for 4 and 7.
oil change coming up, so will do it then.
Lucid
03-31-2016 05:41 PM
rtindle1975
06-11-2014 03:05 PM
Jeff Arkun
04-03-2013 09:49 AM
