p1590????
Old Jan 17, 2007 | 07:38 PM
suntattoo80's Avatar
Default p1590????
hooked up my techforct to my rover and got out a code p1590 the description in alldata is the slabs ecu is sending an error message Hardware OK ....i had a bad wheel speed sensor and replaced it yesterday. The abs has since stoped activating when taking off. A big relief but the ABS DHD And the TC light have stayed on. Does this system need to go through a learning cycle for the light's to go off or is there still a problem???
Thank you all Jason
Old Jan 20, 2007 | 07:24 PM
Default RE: p1590????
bump
Old Jan 20, 2007 | 08:25 PM
Those lights must be turned off by an appropriate scanner like a test book or AutoLogic, they won't go off on their own.
Mike
Old Jan 25, 2007 | 05:21 PM
Trans96am's Avatar
6th Gear
Hi,
I bought a 1999 Discovery II with 101,000 miles .I have the same problem P1590 except the warning lights had the bulbs removed when I bought the truck .I get the3 chimes when I turn the truck off. I was going tohave the brake system powerflushed but does this mean after that is still done I may still have this code untill someone resets it ? I have a engine scanner and can clear engine codes but this may not work for this code ? The ABS modulator has a rebuilt sticker on it from 2005 so hopefuuly that is not the problem. I would like to get this fixed without taking it in to the dealer. Any help would be appreciated. Ken
Old Jan 25, 2007 | 06:16 PM
geoman's Avatar
As Disco Mike stated ---body/suspension/braking system related codes cannot be cleared without hooking up to a Autologic/Rovacomm or equiv. high-end scanner. Typically these are only found at the dealer or at a well equipped Land Rover specialist shop.
Geoman
www.eurotekapg.com
Old Jan 25, 2007 | 10:19 PM
Trans96am's Avatar
6th Gear
Thank you,
If I take the gauge cluster out and replace the missing bulbs and the ABS is fixed will I still have the 3 lights displayed ? Is there a way to see if it is fixed but only needs the computer reset ?
Old Jan 26, 2007 | 10:19 AM
Bottom line, you have to scan the brake system, made the repairs and then reset the lights.
Mike
saltyrover
Apr 25, 2013 06:44 PM
shearer60
Apr 11, 2008 01:26 PM
sanford
Nov 21, 2007 06:11 PM
navysar
Jul 12, 2007 05:18 PM
scottagnew101
Jun 14, 2007 02:50 PM
