P1590
Old Jan 12, 2018 | 07:53 AM
rmcc's Avatar
Default P1590
Hi all,
Had a code P1590- "rough road-implausible reading" came up on the screen. I cannot find that number in any of my lists. Anyone ran into this one before?
Thanks,
rmcc
Old Jan 12, 2018 | 08:15 AM
CollieRover's Avatar
Originally Posted by rmcc
Hi all,
Thanks,
rmcc
It’s related to the ABS system, and is a general fault. You’ll have to scan the ABS system to see if there is an ABS fault that triggered it.
Old Jan 12, 2018 | 08:33 AM
mollusc's Avatar
Mine throws that code constantly, but it doesn't trigger the CEL.
In case you can't read ABS codes, my ABS system gives me a shuttle valve error and a wheel sensor error. I never get the three amigos but I expect they will show up sometime unless I clean/replace the wheel sensor and do Option B.
Old Jan 12, 2018 | 10:09 AM
Best4x4's Avatar
As mentioned above P1590 is a generic fault code. You really need a scanner that can read the actual ABS faults. Once you do that it’ll be much easier to diagnose.
Old Jan 12, 2018 | 04:25 PM
jfall's Avatar
Use this site to look up that code
http://enginecodemaster.com
Old Jan 12, 2018 | 04:28 PM
Friday Night Disco's Avatar
I typically get that code when Tricky Dick has caught a little air.
I just reset it and it is fine till next time I try to channel my inner Evel Knievel
Old Jan 12, 2018 | 05:01 PM
matt3502's Avatar
From the RAVE:
Land Rover Description
P1590 ABS rough road signal circuit malfunction Hardware is OK, but SLABS ECU is sending an error signal
Old Jan 12, 2018 | 06:36 PM
mollusc's Avatar
Mine reappears immediately after resetting, even without driving anywhere. I believe it's related to the input from one of the sensors because the behaviour doesn't change when I change the SLABS unit.
Old Jan 12, 2018 | 06:43 PM
Unplug all sensors, clean, and reconnect
Old Jan 12, 2018 | 07:20 PM
mollusc's Avatar
That's my eventual plan.
I was trying to add possibly useful info for the original poster.
