P1884???
Old Jun 24, 2013 | 02:56 PM
Dan7's Avatar
Default P1884???
Even more confused after I looked it up in the RAVE. Anyone else had experience with this?
Old Jun 24, 2013 | 04:09 PM
clanch's Avatar
Old Jun 24, 2013 | 04:10 PM
clanch's Avatar
Is your base idle high? Or your Can line is down?? Have you cleared the code, and did it come back?
Old Jun 24, 2013 | 04:13 PM
jafir's Avatar
Do you have a scanner with live data? Most of those errors are problems with inputs like TPS, roadspeed, engine speed, etc.
Old Jun 24, 2013 | 04:20 PM
909wheeler's Avatar
Hook up a scanner that can display snapshot data. This is the data captured when the code was set. Look at the data for abnormal/out-of-range values.
Old Jun 24, 2013 | 09:12 PM
Dan7's Avatar
My base idle is not high. What's a "can line"? My code page from the RAVE looks slightly different. It just showed up. I have an UG and I cleared it. Hasn't come back yet but that was just today. I'm prepping for a road trip and would like to make sure there's no issue.
Old Jun 24, 2013 | 10:10 PM
jafir's Avatar
CAN is how the different computers talk to each other.
Old Jun 25, 2013 | 06:33 AM
To give you an answer, I need to know what other codes you currently have, that code is what I call a tag along code and will go away when the other codes you have are resolved.
If you research for the 1884, you will find it pops up for 8 different faults. So what are your other code numbers?
Old Jun 25, 2013 | 07:56 AM
Dan7's Avatar
I did have 0134, 0135 & 0155, however those have been remedied (1 of the 4 prongs on the Dr Side bank 1 female plug was pushed in). 1884 was zeroed out with those after the repair. I currently have no codes.
Old Jun 25, 2013 | 12:02 PM
Good.
