Paint?
You know, thats a really good question, because there are alot of areas inside the truck where the paint color shows. I know there are some spots that the painters probably wont do, but when it comes to the doors i'd be curious to know. If it were my guess I would say yes they can paint it (the inside of the doors) with alot of protective tape and plastic all over the interior.
ORIGINAL: flattrakker
Yeah its prolly a question more to ask the painter but yeah.. im not sure..
What color is it, and what color are you going? If it is drastic, you are going to want to take off all of the door panels and headliner, along with all of the plastic trim inside. If you go that far, you might want to pull all of the weatherstripping and the rear windows. I am painting my roof, and having the alpine windows (and luggage rack)removed to get a clean line. Good time to replace the seals too...
Most times, shops will not paint the door jambs. It takes a LOT more work to sand and mast off jambs. If you are staying with the same color, you want to really stress with them to be EXTRA careful not to get overspray on the door jambs. A lot of shops are sloppy when it comes to overspray. The really consciencious shops take care not to get overspray in the jambs. It's a sign of sloppy work. If you are changing vehicle color, then you probably want the jambs painted. It's not easy to do right w/o removing the doors and trim (around the doors). But the final look is better. Good luck,
motoxxxracer_34
05-20-2005 01:24 AM
