Paneling
Old Jan 28, 2009 | 07:49 AM
And4848's Avatar
Default Paneling
This is a little hard to explain. If I cant get anywhere with the explanation I will upload a pic. On my Disco II, above the back main bumper, on the left and right are two corner panels maybe 4" high that wrap around to the sides. This morning I realized that my left side panel is moving, and with a bit of inspecting realized that the plastic rivets holding it on have cracked. Does anyone know of this problem happening before? If so, do you think it will be something I can find a part for? I am of course going to try roverlandparts. Figured I could float it out there to see if anyone ever had the same ordeal. Thanks.
Old Jan 28, 2009 | 10:11 AM
Default RE: Paneling
It happens and replacement clips are available as is the corner trim if needed.
Old Jan 28, 2009 | 03:00 PM
tex599's Avatar
I bought clips from the dealer for .65 cents each for my trim piece. I think each piece is help on by 2 clips.
Thanks
Old Jan 28, 2009 | 06:47 PM
Disco2Guy's Avatar
My corner pieces have popped off a long time ago. In fact the right side of the bumper is pushed up a good 3/4" and now the corner caps won't even line up. Since my truck is black I don't care because the color hides the holes better than a lighter color paint.
