Panhard Bar Conversion w/ Pics!
Old Oct 28, 2014 | 06:32 PM
  #21
cybercop's Avatar
Is welding to the side of the diff like that really a good idea and common practice?
Old Oct 28, 2014 | 08:56 PM
  #22
dusty1's Avatar
fine as long as you don't get stupid and blow through, but that is fixable too. if anything it gave him incentive to crawl under and deal with some of that rust.....that more detrimental to the housing than the welding.
Old Oct 29, 2014 | 07:41 AM
  #23
adventr's Avatar
No issues welding to axle housing. That's how the stock brackets are attached.
Old Oct 29, 2014 | 08:37 AM
  #24
ZGPhoto's Avatar
I would probably recommend plating that stock upper driver side bracket with some thin steel just to strengthen it a bit, it is going to experience more force than the original design.
Old Dec 23, 2014 | 10:37 PM
  #25
toofaroffroad's Avatar
Default panhard conversion
Hi I joined the club this past weekend. so easy and so much better. My Watts was clunking and rattling and I had already replaced it 4 times in 4 years. One question though, where are you guys measuring to get the rear diff centred? I kind of eyed it up looking at each side from the back but i'm sure there is a more scientific way.
FYI 1.5" more down travel with the pan hard.
Old Dec 24, 2014 | 09:03 AM
  #26
OffroadFrance's Avatar
Has anyone considered a rose jointed A frame as an axle location option. I haven't looked into the pros or cons as such as I use all of my trucks as stock. I'm not sure whether someone even has tried or makes them so far but maybe a better locating system than a Watts or Panhard. I'm not too sure about the ultimate extreme articulation though.
Old Dec 24, 2014 | 12:20 PM
  #27
binvanna's Avatar
What is the advantage of the Panhard rod over a Watts link? I thought the Watts was superior? I can see where a stronger, heavy-guage DOM link or a longer link could be desired in the case of a significant lift, but the Watts is a good design. Isn't it in fact the radius arms that limit flex in the rear?
Old Dec 24, 2014 | 12:53 PM
  #28
TOTM: Rear Triangulated 4-link suspension - Pirate4x4.Com : 4x4 and Off-Road Forum
Old Dec 24, 2014 | 01:04 PM
  #29
dusty1's Avatar
every little bit helps. watts is a good design has its limitations and can be a hurdle in articulation of a lifted truck. radius arms are the limitation once you overcome that. link it or customize longer arms is the next thing
Old Dec 25, 2014 | 01:58 PM
  #30
ZGPhoto's Avatar
The panhard rod has several advantages, and I doubt there are any real disadvantages.
As an aside, ruffstuff is having a 20% off sale right now until January 1st. That means you're getting a full kit to do this swap for around $145 or so, about half of what the genuine bushings cost.
ZGPhoto
Dec 15, 2015 10:46 PM
ZGPhoto
Jun 20, 2013 08:31 AM
thehun
Mar 7, 2013 01:35 AM
honda50r
Feb 15, 2013 10:47 AM
collector87
May 16, 2012 05:11 PM
