Panhard rod bushings.... stock or poly?
Old Mar 16, 2014 | 03:33 PM
MarkSF's Avatar
Default Panhard rod bushings.... stock or poly?
And if poly, which grade? Black, blue, yellow?
Going to replace mine soon, as they seem a bit iffy.
Old Mar 16, 2014 | 04:03 PM
OffroadFrance's Avatar
Pink!!
I'm going down the same route at the mo. I'll look into it and post my results. It may also depend on what you primarily use the truck for. I can imagine different colours = different grades of stiffness for different applications. I'm looking at polybush for ordinary highway use but I have to admit the OEM has lasted 11 years and 121K miles.
Old Mar 16, 2014 | 04:06 PM
Pink!!
PS. I've found some results on a UK website:
Red - (Performance) similar to original spec [would be my choice]
Blue - (Comfort) very soft compound - excellent articulation etc - will wallow like a pig on road
Orange - (Dynamic) not available for all vehicles
These are UK colour ratings so US may be different.
Old Mar 16, 2014 | 06:58 PM
Madlands's Avatar
If you are doing it yourself and you want easy then definantly go polybush. I went with the orange polybush from lucky8 a few months back and they are great. I use mine as a DD and as bushings need replaced I've started swapping the polybush. You cannot beat their ease of installation either.
Old Mar 16, 2014 | 09:20 PM
Fivespddisco's Avatar
We have had good luck with the polybushings and Orange are the ones we recommend.
Old Mar 16, 2014 | 09:48 PM
zeroone's Avatar
Could these cause a vibration if they are in need of replacement? I'm still trying to figure out my vibration.. I'm questioning everything until I figure out what it is.
Old Mar 17, 2014 | 12:38 AM
jfall's Avatar
Only poly.
Some stock are actually now made in China and are total crap.
Plus oil leaks eat up the rubber on Stock.
Oil has less effect on Poly
Rover Newbie
Jul 17, 2014 07:47 AM
MM3846
May 7, 2014 07:17 PM
jfall
Dec 9, 2012 07:28 PM
JPSpen
Oct 15, 2012 10:51 AM
moomoo
Jun 16, 2011 08:20 PM
