PARK BRAKE QUESTIONS
Old May 3, 2007 | 04:03 PM
desh72's Avatar
7th Gear
Default PARK BRAKE QUESTIONS
I recently purchased my first LR specificallya Disco II and I have a question regarding the park brake. There isnt much tension when pulling the lever and my warning light is always on, is this normal for the brake lever and what can cause the brake light to come on. Brake fluid level checks out ok.
Any help would be much appreciated.
Old May 3, 2007 | 06:01 PM
Default RE: PARK BRAKE QUESTIONS
You may need to get the brake switch for your e-brake adjusted.
Mike
Old May 3, 2007 | 07:51 PM
okdiscoguy's Avatar
also, your park brake acts on the rear driveshaft. It is the drum at the front of the shaft.....so you know.
Old May 5, 2007 | 12:24 AM
deadclock's Avatar
I didn't know mush about park brakes. That's the rarest among my brake parts that I touch... What I'm familiar with is the VW brake hose since I had that problem once withmy old car
Old May 5, 2007 | 12:03 PM
Also just to clear up one thing, if you have the truck off the road with the t/case locked up, the e-brake will also lock up the front wheels.
Mike
Old May 5, 2007 | 12:54 PM
okdiscoguy's Avatar
true...if your D2 has a diff lock...
Old May 5, 2007 | 01:17 PM
Good point
amer_qureshi
Jul 10, 2024 02:03 PM
klkernan
Sep 6, 2009 12:12 PM
FJL
Aug 20, 2009 01:42 PM
FJL
Aug 20, 2009 12:10 PM
togo
Jul 22, 2009 05:34 PM
