Parked Battery Duration
I don't think the solar battery chargers have the same level of sophistication is a battery tender IE they don't shut off as a battery get stopped up so they're probably overcharging in a little bit but I don't know that for sure. I know they do keep it topped up right to the top. I would not leave them outside, I throw them on the dash of the truck and park them facing the Sun
Simple solar chargers are usually self-regulating, so they don't overcharge. Sophisticated solar panel systems need a regulator to keep from overcharging. I'd be surprise if the HF charger overcharges. Easy to test battery voltage on a sunny late afternoon. Less than 14.4 V or so is not overcharged.
I have a 15W Battery Tender brand solar charger (and plug-in chargers), they are regulated and won't overcharge. In my D2 I also run a "dashcam" that keeps going when the ignition is off. There is a voltage sensor inline that will shut down the dashcam when the voltage gets low. For extended periods I like to keep the solar charger going so that dashcam keeps running too.
