Parked Battery Duration
Old Feb 14, 2022 | 11:07 AM
Extinct's Avatar
I don't think the solar battery chargers have the same level of sophistication is a battery tender IE they don't shut off as a battery get stopped up so they're probably overcharging in a little bit but I don't know that for sure. I know they do keep it topped up right to the top. I would not leave them outside, I throw them on the dash of the truck and park them facing the Sun
Old Feb 14, 2022 | 10:28 PM
JohnZo's Avatar
Simple solar chargers are usually self-regulating, so they don't overcharge. Sophisticated solar panel systems need a regulator to keep from overcharging. I'd be surprise if the HF charger overcharges. Easy to test battery voltage on a sunny late afternoon. Less than 14.4 V or so is not overcharged.
Old Feb 15, 2022 | 11:14 AM
Sean Maginness's Avatar
I have a 15W Battery Tender brand solar charger (and plug-in chargers), they are regulated and won't overcharge. In my D2 I also run a "dashcam" that keeps going when the ignition is off. There is a voltage sensor inline that will shut down the dashcam when the voltage gets low. For extended periods I like to keep the solar charger going so that dashcam keeps running too.
Old Feb 15, 2022 | 11:24 AM
redwhitekat's Avatar
i used to let mine sit for 5-9 days ands its cold here in ontario canada this year and used to fire right up maybe you have a weak battery
Old Feb 16, 2022 | 11:51 AM
dswilly's Avatar
I feel lucky. I went 3 weeks in December and it started up no problem. I do like the idea of a solar charger.
Old Feb 16, 2022 | 09:10 PM
Harvlr's Avatar
I don’t think 3 weeks should be too long. I can even leave my P38 for 3 weeks without a charger and it will fire right up.
brydonsearle
Jan 15, 2022 04:25 PM
mmbirtcher
LR4
Oct 13, 2021 04:27 PM
Angela Clow
Range Rover Evoque
Mar 22, 2021 08:42 AM
primo
Mar 29, 2011 06:55 PM
co556guy
Jun 30, 2009 04:22 PM
