Parking brake problem
Old Jan 26, 2009 | 05:25 AM
DiscoRom's Avatar
Default Parking brake problem
My parking brake does not want lock in place when I pull it up.
The button at the tip stays depressed after I press it.
I have to jolt it at the side so the button can pop out and lock in place.
What can I do?
Old Jan 26, 2009 | 05:28 AM
Disco Dave's Avatar
Default RE: Parking brake problem
sounds like an adjustment is needed in the cable. over time they can stretch. i've had this problem with other vehicles, so i assume it can also happen with LR's
Old Jan 26, 2009 | 07:01 AM
unimoged's Avatar
Inside the handbrake handle, the button controls a rod that engages / disengages a link that locks into teeth on a stationary bracket. There is a spring that pushes back the bulton, locking with the stationary toothed bracket. I am assuming that the spring is damaged or the mechanism is gummed up.
Old Jan 26, 2009 | 01:43 PM
DITTO
Old Jan 27, 2009 | 03:47 AM
DiscoRom's Avatar
I figured it out!
The parking brake is slightly bent downwards (maybe someone stepped on it)
That's why the rod when it passes through metal tube gets stuck when I press the button.
Lots of WD-40 and a bit of elbow grease did it.
Small gratifications like that make my day. You don't get that from newer trucks.
Thanks.
Old Dec 23, 2012 | 10:43 AM
Michael M. Koch's Avatar
Going to resurrect a (very) dead post here, but after replacing my parking brake cable I'm having the same issue.
Can this spring be replaced, or do I essentially need a new handbrake lever? And, if so, what are my best sources for such an item other than the boneyard?
Old Dec 23, 2012 | 10:48 AM
lr2001silver's Avatar
Banned
Holy wow old thread man......
I would just call Paul Grant he will get you one that is good and you will have no worries. Paul is not a salvage yard as much as he is a dismantler they take trucks apart and stock pile the parts we will need to keep the wheels turning. His stuff is stored inside.
Old Dec 23, 2012 | 09:12 PM
Haha, yeah I know it's old. But it did turn up while researching my problem. After the holidays I'll probably call Paul Grant, as you suggested. Thanks for the help!
Barnettz
Sep 5, 2013 03:07 PM
tibyABv6
Dec 18, 2012 10:09 PM
mx468
Oct 6, 2012 02:04 AM
zach
Aug 22, 2007 01:23 PM
