Parking Brake... removal?
Old Sep 9, 2007 | 06:48 PM
ajh's Avatar
ajh
Default Parking Brake... removal?
I've looked at X-Brake (disc transmission brake to replace the drum) and the local Rover wrecker is making his own Disc replacement as well. What I'm wondering is if I am going to upgrade my calipers all around then I could install some mechanical parking brakes on each disc. Anyone heard of something like this being done? It would cut a pile of weight off the drivetrain though I'd probably have to do a new rear propshaft or make a spacer.
Can anyone think of other advantages that having wheel brakes vs transmission brake would have?
Old Sep 9, 2007 | 07:52 PM
Default RE: Parking Brake... removal?
There is no up grade for Disco rotors at this time. Yes I can see how the removal of the e-brake would shed a little weight.
Old Sep 9, 2007 | 08:33 PM
okdiscoguy's Avatar
I have always thought that having the brake at the rear wheels was a safer thing to do. With the open diff on the Rover, it could still slide. Doesn't seem very safe to me...
Old Sep 10, 2007 | 07:29 AM
Off road, while locked up is not an issue cause the e-brake will lock up a front wheel also if your CDL in engaged.
Old Sep 10, 2007 | 09:55 AM
okdiscoguy's Avatar
ORIGINAL: Disco Mike
if your CDL is engaged.
That was my point. Some you can't engage CDL. I wasn't thinking about this being a safety issue for people that know their trucks. Not too many people read the owner's manual or check the location of the parking brake before helping someone change a tire on the side of the road.
tibyABv6
Dec 18, 2012 10:09 PM
damnlows10
Jun 23, 2008 06:35 PM
houstonhelix
Mar 16, 2008 08:54 AM
zach
Aug 22, 2007 01:23 PM
