Part # for Brass Fill Plug
Old Mar 22, 2009 | 06:57 PM
Disco Alan's Avatar
Default Part # for Brass Fill Plug
I'm planning on doing my diff and t-case fluid change and learnt on this forum that it's a good idea to replace the plastic plugs on the diffs with brass plugs. Does anyone have a LR part number for this? Thanks.
Old Mar 22, 2009 | 07:01 PM
http://www.roverparts.com/Parts/FTC5208G.cfm?bc=ab
You can also go to Home Depot and get them from plumbing supplies.
Old Mar 23, 2009 | 10:42 AM
Disco Alan's Avatar
Thanks Spike. Just so that I'm completely clear - that means I can get 2 more diff drain plugs and put them in the fill holes?
And if I go the Home Depot route what kind of fitting am I looking for? Is it going to be a hex fitting like the plastic plug or a square one like the drain plug?
Old Mar 23, 2009 | 10:53 AM
If you want the true brass plugs, call John at Expedition Exchange, that is where I bought mine and they are far better the the old slug plug cause they also come with a built in rubber o-ring.
Old Mar 23, 2009 | 12:12 PM
Take one of your diff drain plugs to Home Depot and tell them that you need 2 more of these exact same things.
It will cost you about $5 for 2.
You can put thread tape on the threads why you put them back in. Even if you dont they wont leak.
Old Mar 24, 2009 | 11:10 AM
Disco Alan's Avatar
Thanks a lot Spike and Mike. The EE brass plug certainly looks very nice but boy are they expensive. I may still get these but I'll take a look at Home Depot first.
Boxkid1
May 15, 2012 09:31 PM
Disco Alan
Apr 21, 2009 06:22 PM
bigugly82
Mar 19, 2008 10:16 PM
kschintz
Jan 3, 2008 11:58 AM
tbesselman
Oct 10, 2007 09:26 AM
